NW Iowa | Did you do the “flag test” in the 20/20 to see if your gps measurements were correct? If you are exporting gps out of a Nav II or III serial cable on your Trimble system, it outputs the rear axle, not globe position. So your gps globe offest would be would “0” in from the rear axle in your tractor measurements in your 20/20. I’d start there and verify that’s all correct first. Not sure if that would cause the coverage to map incorrect or not but something to check. | |
