| Anyone have a good suggestion on how to thin a stand of corn? Gps planter prescription didnt work or the hired hand didnt select the prescription. Dryland corners are planted at 28k along with the 28k irrigated center pivot acres. Was supposed to be 28k under the circle and 16k in the dryland acres. The ground is extremely sandy and even at low population the corners struggle when heat and dry weather hits. Central tx | |
