Search Forums | Classifieds (28) | Skins | Language
Weird effect from roundup
boog
Posted 7/22/2006 10:56 (#28869 - in reply to #28824)
Subject: Re: Weird effect from roundup
Neighbor sprayed Roundup (not generic) a few years ago & it drifted across the road and probably out into our corn about 200'. 1 st row or 2 on the edge of the field was dead & the damage tapered off from there. You could see where it drifted down thru the lower area of the field. Have had other similiar instances where either Roundup itself was used or a generic brand . Usually sprayed by custom operators whp will put anybody that walks in the seat.
I use ULAI nozzles & whne i am spraying along a cornfield I always lower the boom as much as possible & slow way down. If wind is towards the neighbors I either wait till wind has changed directions or will leave the ends till latter. So far I haven't damaged anyone else's crop or garden, at least no one has called me.
