Posted 3/18/2008 23:48 (#337186 - in reply to #337167) Subject: Re: Replacing Holley carb with Edelbrock carb
Brazilton KS
The AFB will start and run, it won't dry up and leak, it won't flood out because the float can't take bouncing, it won't destroy the power valve the first time the engine backfires.......
If you have got the impression I like the AFB a lot better then the Holley, you are correct :)
