Search Forums | Classifieds (46) | Skins | Language
fertlizer placement
plowboy
Posted 9/6/2006 00:49 (#41740 - in reply to #41647)
Subject: Re: fertlizer placement
Brazilton KS
The normal practice here is to fertilize for both crops in front of the corn.
Deep placement is proven to pay. There is plenty of research to back that up.
I realize that Jim and I may have gone around on this point before, but I have a problem with reducing fertilizer rates regardless of placement. Removal is removal and anything less then that is going to erode soil test levels. Nothing you can apply in a given year will fully compensate for loss of good soil test levels. You may get equivilent response on a one-year basis with lower rates due to placement, however in the long run there will be a cost. The other side of this is that you should see a yield response to placing the same amount of fertilizer in a better postion.
