Southern Missouri | Exactly how ours is setup Robert, we have 1.5 inch hose feeding from elevated shuttles (4) to 50 gal cone that’s plainly marked in gallons all the way from bottom to top , the four shuttles are valves into top of cone on the side , can drop 10 gallons of chem in there quick , while standing on the ground, never leave the ground using our tender trailers , spraying every acre of cotton 11 to 13 times per season will cause you to spend time making your tender trailer work fast .Phosphonic acid , prep cotton defoliant , will screw up anything it comes in contact with in a hurry , pumps , meters etc , doesn’t bother this type of shuttle system, just don’t let it get on your pickup paint .
Edited by sloughclub 3/10/2024 12:33
