Search Forums | Classifieds (72) | Skins | Language
Clean Sweep run with 20/20 AirForce compressor?
doublev35
Posted 4/10/2024 14:52 (#10701771)
Subject: Clean Sweep run with 20/20 AirForce compressor?
NW Iowa
If trying to run Clean Sweeps on manual set point control is there any way to control the Precision AirForce compressor without using a 20/20 SeedSense monitor??  We have a 1770NT16R30 CCS set up with all Ag Leader SureSpeed/SureForce that we are now adding new clean sweep cylinders to.  We already had a used Precision Planting 20/20 AirForce 10 gallon compressor that we are trying to use but it is wired up to run through the AirForce control system.  I have the hydraulics plumbed into SCV 1 frame lift and CCS fan run on constant, I can't get the compressor to operate. Since we do not have a 20/20 seedsense monitor I am hoping we can somehow bypass the AirForce controller/wiring and just run the clean sweeps with the manual control box in the cab.  Does anyone know if this is possible without the 20/20 monitor and if so how would I go about rewiring the compressor to work manually?  Any advice is appreciated, thank you!
