Posted 10/17/2007 00:28 (#220994 - in reply to #220812) Subject: RE: Agronomists, is nitrogen all the same?
Since you were an agronomy major, go here (http://www.isafarmnet.com/) and figure it out yourself. Lots of side-by-side trials over multiple years and production systems. If I tell you the answer, you won't listen or believe. You already know that the plant only cares about one form so the issue is what are the losses in getting the applied form to a plant useable form. Let us know what you conclude.
