Search Forums | Classifieds (22) | Skins | Language
corn yield estimate?
Guest
Posted 8/10/2006 09:17 (#34317 - in reply to #34280)
Subject: Re: corn yield estimate?...TW
You said " My example has 21,000,000 kernels of the same size but the hight test wt. sample weighs more."
THATS IMPOSSIBLE, if two samples of 21,000,000 kernels are the same size (measured by seeds/lb.) Then you have the same number of pounds in each sample, hence they yield the same, the heavy tw sample just takes less space.
